After marking what might be the last trim line of the top cowl, trimmed the cowl using 60 grit and sanding block. Put the top cowl in place to check fit with the firewall flange. It looks pretty good, just a few places needing attention.
Blue tape marks the trim line
Test fitting after trimming
Reverse lighting to help with locating canloc holes
