My RV-8 Build Log
Date:  3-8-2016
Brief Description:  Riveting Camloc Tabs to firewall Flange - II
Completed riveting the Camloc tabs to the firewall flange. Just to keep things a bit simple, I riveted the longer rivets first (where tabs overlapped), then rivet the remaining holes. If remember correctly, the longer rivet was AN426-4-5, and the short AN426-4-4.5.
In the lower left tabs of the bottom cowl, has to drill for the fuel drain that comes from the mechanical fuel pump.
Completed riveting tabs to firewall flange
Left bottom tabs to firewall flange
Underside of firewall flange and camloc tabs
