Brief Description: Final behind the panel woring work
Installed a LED to indicate when the starter is engaged, as wells as (3) TRS 3.5mm jacks
(1) Pilot music to GMA240 audio panel (2) Rear Seater music to GMA240 audio panel (3) Rear Seater phone to GMA240 audio panel
The thinking here, since the GMS240 supports all of these functions, get the wiring done now because adding later after the top skin is in place is going to be a LOT more work.
The phone jack wiring is not very descriptive in the Garmin doc, apparently because different phone manufacturers do different things with the terminal, ring sleeve call-out.
