My RV-8 Build Log
Date:  8-18-2015
Brief Description:  Elevator Trim and A/P Servo wiring
Using a hint from Steinair, decided to extend the elevator trim motor wiring by crimpling pins and heat shrink the (5) wires - (3) Indicator wires and (2) elevator trim motor.
The elevator trim motor will be driven from the Garmin GSA 28 pitch servo, so that it is airspeed sensative (less trim action at higher airspeed). To do this, the power for the elevator trim motor is derived from the GSA 28 pitch servo, the trim motor indicator goes directly to the GEA 24 monitor for display on the GDU 460.
Crimped pins and heat shrink
Elevator Trim wiring with Garmin servo
