Brief Description: Test Fitting LRUs in new panel...
Test fitted all of the remaining hardware for the instrument panel, just to make sure everything fits as needed and there are no new clearance issues. I did have to notch the instrument panel flange at the top left of the audio panel so the audio panel slides into the tray.
For this version of the brackets, I bent the support angles inside of the bracket, instead of outside as I did with the original. It looks better, and there is no clearance issue at the lower right where the circuit breaker row starts.
