My RV-8 Build Log
RV-8
GSA 28 Pitch Servo Installation #4
Riveted the GSA servo / elevator bell crank brackets to the airframe. To ensure this went well, I removed the servo motor, but kept the rear spacer and squeezed the forward (3) rivets on each side. I had to buck the final two rivets on each side.
GSA 28 Pitch Installed Left
GSA 28 Pitch Installed FWD
GSA 28 Pitch Installed Right
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
