My RV-8 Build Log
RV-8
Install Ammeter Shunt
Installed Ammeter Shunt on firewall under the battery tray. Need to decide how and by which means to provide the 1A fuses needed for the shunt.
I can monitor battery or alternator… or both if I really want if I install another shunt. Leaning toward battery.
Ammeter Shunt Wiring Requires In-Line 1A fuses
Installed shunt under battery tray on firewall
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
