Determined best routing for Oil Temp Sensor wiring to the shielded wire from the GAE 24. Added more heat shrink to the base of the wire at the sensor to provide a bit of additional protection since the wire is in close proximity to braded flex line going to the Oil Cooler.
Located an appropriate place to splice the wires from the sensor to the GAE 24, stripped and crimped ring connectors. Used Heat Shrink to provide insulation.
