My RV-8 Build Log
RV-8
Install UMA Tach Sensor
Removed the magneto, this took a bit of coaxing for some reason, a little twisting.
Installed the UMA tech sensor per instructions, using a bit of blue goo, re-installed magneto finger tight so it can be timed at a later date.
Magneto removed...
Tach Sensor Installed
Back on the engine, finger tight, not timed
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
