Brief Description: LH Aileron Counterweight and Aft Spar Trimming
I drilled out the LH aileron mounting holes for the counterweight and installed the aileron and weight to check the fit. Both aft wing spars needed to be trimmed a little to clear the counter weight arms. I trmmed them back to allow about a fingers width space between the arm and the spar end. Still need to seal the spar end foam.
