Spay glued the flap rib drawing to a piece of 1/8 inch chip board. Cut them out and shaped the patterns on drill press with a sanding drum. I then routed ribs out of 1/2 inch 5 lb foam using the chipboard patterns on the router table with a pattern bit. I cut ribs for both flaps. The bottom contour fit pretty well with the flap lower skin
