Removed the ailerons from the table and cleaned up the trailiing edges with a sanding block. I then prepared the outboard ribs for the final two ply layups. First I plugged the counterweight attachment holes with play dough to protect them from resin. Second I made a small q-cell radius between the top skin and the rib. After this set up I applied the two ply layups. these are a little tricky with a brush and the small work space. All came out well after a little bit of fiddling.
