Made the two ply closing laminates that tie the LE of the upper and lower aileron skins together. I made a very small qcell radius in the corner to help the laminates lay better. The laminations can be done with about 35 grams of resin per aileron. The ailerons are still clamped to the flat table for this step. Laminates were a little tricky because my table is up against a wall. This required reaching over the aileron to make the laminates. It was a little tough to see with out straining the neck!
