Bill's Glasair Odyssey
Date:  12-17-2010
Brief Description:  RH Flap HInges - Drilling to the wing
I got some replacement piano hinge from Aircraft Spruce to replace my fishy hing half. I made up a new piece and match drilled it to the bad piece and reinstalled it on the flap shear web. I then went through the fitting of the flap to the wing and clamped and drilled the wing side hinges, same technique as the LH side
