Brief Description: Wing Tip Flanges, Upper Wing Skin
Spent the first part of the session sanding the nine ply wing skin build ups flush with the rubber spacer. Eight plys may have been a better choice. The sanding took a while! I then cleaned everthing up, waxed the rubber space and made the first three ply flange layup on the RH tip. Had to cut it short and did not have time to do the LH side this session. 80 gram batches work out about right for each three ply layup.
