Brief Description: Elevator Trim Bellcrank Hardpoint Installation
I installed the 20 lb foam hardpoint for the elevator trim bellcrank in the A rib. This was done per plans. I used a 1 by 2 drill jig and a forstner bit to drill the 3/4 inch hole in the LH skin of the A rib. This works good but is tough on the bit. I added the 20 lb foam plug and the two ply layup over the plug. I also redrilled the seat belt attach fitting holes.
