I redrilled the LH inboard seat belt bracket holes in the wing based on yesterdays flap motor mock up. I then turned the wing upside down and cut out the last bottom skin for the 20 lb foam insert. I then sanded back the gel coat in preparation for the 3 ply layups that will be placed over the foam inserts. All I have for 20 lb foam is 1/4 inch thick. Each insert will consist of two stacked pieces of foam. I potted in three of the inserts and called it a night. One to go tomorrow.
