Brief Description: Standpipe Mounting Ring Installation
I installed the mounting ring per the manual using stacks of washers to set the proper angles. Because I am an engineer and I have a digital level I spent way to long screwing around with the washers and such! I mixed up 40 grams of mill fiber to bond the ring in place. I should have mixed more mill fiber as I barely had enough to fill the gaps flush. The manual has you make transitional fillets with the mill fiber. I had to go back and add mixture of mill fiber and cabosil to ease the transition between the ring and the wing skin. I added the cabosil to make the mix spread a little smoother.
