I loaded the wing into the rotator with my buddy Kelly's help. I then worked on clamping my long extrutions to the top wing skins at the trailing edges. I then put a fillet of bondo at the intersection of the extrusion and the wing skin. The idea is that the extrusions will hold them straight while I complete the rear spar layups which I will do over the holiday weekend. I also ran some test batches of resin just to make sure everything was still good.
