Added the two ply laminate on the upper wing skin centerline seam. I layed up the tape on tin foil on the bench. This task really should have taken 45 minutes but I messed up the first attempt by losing control of the two ply laminate. Needless to say I pulled it up and cleaned off the resin for attempt number two. Second time is a charm.
Prior to the seam lamination I worked on the stack of unidirectional I had done a couple of nights ago. The short ends needed to be tapered so that the single ply bid sealing laminate will lie nicely.
