Resized all the LH wing ribs to make room for the two ply capstrips I will be adding. This is the same process that I did on the RH wing about five sessions ago, same tools, same techniques. I also trimmed on of the RH wing rib capstrips just to see what the end result of all this effort will look like. I am very happy with the results. I think this technique will result in a significantly nicer wing structure.
