Pryed the upper wing skin away from the ribs. It required considerable effort to get the capstrips to release from the wing skin. All the capstrips released and were bonded to the ribs, success. A couple of the nose rib glue joints broke during the release process but it was easy to put them back into position. I then mixed up some thick Q-cell and put a fillet between each of the rib to capstrip junctions. This will bond them along there entire length and provide a smooth transition for the two ply laminates that will be added tomorrow. This process has worked well.
Capstrip Attached to Rib, Dark area's are cabosil blobs.
