Brief Description: Capstrip to Rib Bonding - RH Side
I applied blobs of a thick cabosil mixture to each of the ribs then put the RH wing skin in position. I weighted down the wing skin in the same manner that I will use for the actual wing closing. I will let this cure and then hopefully the capstrips will stay attached to the ribs when I open the wing skin.
