Bill's Glasair Odyssey
Date:  1-19-2009
Number of Hours:  3.75
Brief Description:  Wing Tip Rib Fabrication
The G1 construction manuals do not show a tip rib in the wing. Dace Kirk suggested that I add one. I agreed that the G1 method leaves a lot of tip span with no ribs so I decided to follow his advice. I created a template for the rib using two pieces of 1/8 inch masonite. I replicated the wing skin profiles using a washer run along the skin with a Sharpie pen in the inner hole. This makes a nice tracing (see pic 1). After both wing skins had been traced I cut the templates on my bandsaw. The templates were then placed in position and hot melt glued together. The template was used to mark the 1/2 inch foam for the ribs. The ribs were cut, fit, sealed with Q-cell, then glued into position using a thich Q-cell mixture. A fillet of Q-cell was made around the perimeter of the rib to ready it for the laminates to follow.
Tracing Lower wing skin profile using washer technique
Finished two piece rib template
Rib Q-celled in place LH side
