Worked on rib fitting a little. Cut boards to place on upper wing skin to distribute loads from weights to be used for wing closing. I am planning on using concrete fence blocks. Filed 45 degree angle into RH wing vent tube. Still need to secure both vent tubes and complete the mounting pad for the pitot static tube.
Placed boards on LH wing skin and used all the weights that I have to load the wing skin down. Check fit of all ribs aft of the main spar. Everything looks pretty good. Forward of the spar the nose ribs still need a little trimming.
