Routed out the wing rib holes (originally for 1/4 inch tubing) to fit my 3/8 inch tubing. Ran tubing from tip to LH wing skin elbow. Ran the lines to remain clear of the wing center line which will have a GII fuel stove pipe installed. Made a two ply laminate patch of the LH and RH wing tip closeout rib. These were for a different vent system than I am going to use. Tomorrow I will fill the holes from the outside with cabosil and put an additional two ply patch on the outside.
RH and LH vent lines attached to the LH wing skin fittings
