Bill's Glasair Odyssey
Date:  2-18-2008
Number of Hours:  2.50
Brief Description:  RH Inspection Access Hole/cover
Started working on the wing inspection access openings. I am diverting from the plans a little here. The planes have you just cut all the way throught the bottom of the wing resulting in about a 1/2 inch thick disk. Then a 2 ply pre-cure flane is laminated to the inner wing skin. Too easy for me! I have elected to build them more in the Rutan fashion. I won't try to explain here, I will add photos. Anyway my first attempt at using my Dremel router ended with the bit wandering out of the dremel and cutting through the wing! Woops! Easy fix. Stay tuned.
After Routing and Sanding
Router with Circle Guide
