Started focusing on the nav light notch on the wing tip. I cut off the portions of the flat areas that did not line up (not in the same plane). I also made some relief cuts that allowed me to adjust some of the fit. I then layed up two plys of BID on the notch areas to stabalize everything. Once these cure I can tape from the inside and sand the notches to shape. Most of the laminates that I did today will likely be sanded away.
