Brief Description: Wing Tip Lower Flanges and Seat Pans
I layed out the hole pattern for the seat pan flanges, drilled .125 holes, and clecoed. I then removed the flange layup from the seat pan and marked for cutting. I cut the inside flange from the pan and then put the flange back on with the clecos and put the pan back together. I then started the same process on the RH seat pan. Layup the four plys for cure overnight.
I also trimmed the excess off of the wing tip flange reinforcements. I used my Fein tool to get close and then sanded the reinforcements flush with the existing flanges.
