Brief Description: Wing Tip Flanges and Seat Pan Blister
Added three plys of heavy UNI to each lower wing tip flange. I did these one at a time and let each half cure before adding the next.
While I was waiting for the UNI to cure I grabed the LH seat pan and fabricated a mold to build a blister over the flap motor. I used a cardboard mailing tube and some foam to make the form. I covered the form with some bagging film and taped it into position. I then layed up four plys of bid over the form and about an inch onto the perimeter of the cut out. I sanded the gel coat off of the edge of the cut out prior to laminating
