This afternoon I finished the RH side seat pan cutout by cutting the strip of material I added yesterday into the proper shape. I did this with a jig saw and finishes with a sanding block and drum. I then laid out the seat pan mounting holes in the upper wing skins and drilled the upper wing skins. I could not find my strap duplicator to transfer the holes to the seat pans. I will work this tomorrow... I hope.
