Trial fit LH landing gear. Forward four ply laminate needed to be sanded to fit the gear. I am guessing I removed approximately one ply of the four I added before the gear fit properly. At that point I started addressing the aft trunion mount. I sanded out the filler and checked the fit of the gear. I then used some precured squares to try to figure out how many plys needed to be added. Two ply precure fit snuggly. I decided to use a three ply laminate to give me some sacraficial ply to sand the pad perfectly flat and adjust the gear fit.
Completed Forward Pad After Sanding to Proper Thickness
