Bill's Glasair Odyssey
Date:  1-2-2009
Number of Hours:  3.00
Brief Description:  LH trunion mount plate rework
The landing gear installation was started by a previous builder. On the LH side had some mystery filler on the fwd and aft landing gear partial spars on the landing gear trunion mount pads. I decided that the filler was not the right answer in this location. I sanded out the filler on the forward spar and added four plys on bid in its place. I will adjust the fit of the gear by sanding into the additional laminates as required. After the fit is proper I will sand out the filler on the aft partial spar and add plys to fill the gap.
Starting To Sand Away The Filler
Filler Removed Ready For Layup
Four Ply Layout Complete
