Bonded the core to the LH gear door in position on the wing. I used Q-Cells to bond the foam and sandbags to hold the core and the door skin into the wing airfoil shape created by the MDF structure I built up yesterday.
I also started setting up for locating the pitot tube. I cut a V notch into a straight board to use as a fixture in locating the pitot tube.
