Brief Description: Fit Landing Gear Scissors, Brake Calipers
Installed the new style gear scissors on the main gear legs. Installed the brake calipers and backing plates on the main gear. The calipers require a little grinding to clear the gear half forks. I also mixed up some cabosil and injected it into the holes in the outer wing ribs that I had started to repair a couple of days ago. I used a syringe to fill the holes hopefully to eliminate air bubbles.
Black line on right ear of caliper shows material to be ground away
