Brief Description: Drilled path throughs for hydraulic bulkheads in r
I drilled the four pass through holes in the rear wing spar for the main gear hydraulic line bulheads. The final size is 7/16" diameter. I stepped this up using about four different drill bits. I backed-up the holes with 3/4 inch MDF to keep the drill from wandering and tearing up the laminates.
