Brief Description: Aileron Bellcrank, Elevator Control Sleeve
I re-layed out another bellcrank blank for the left hand aileron. This is to replace my first attempt that did not bend well! I also cut out a spacer sleeve to hold the spacing on my elevator control sleeve. I am welding some additional 4130 plate to the sleeve to strengthen the control arm. An old addendum has you rivet in a block of aluminum instead of welding but I like the weld option better.
