Brief Description: Control Hinges, Mold for LG circuit card
Just back from Oshkosh! Lots of beautiful airplanes.
Finish filed the flap and rudder hinges edges. Cleaned off the dye chem with MEK.
Sanded radii into the mold blank for the landing gear circuit card cover. I know have to attach it to a base plate (more MDF). I will then build up a radius between the blank and the base with bondo, sand, coat with epoxy, sand, paint and then it will be ready for use!
