Bill's Glasair Odyssey
Date:  7-14-2010
Number of Hours:  1.50
Brief Description:  Pitch Trim Mechinisms
Today I positioned and drilled the mounting holes for the pitch trim lever. The angle mount through the top wing skin a little left of the wing center line. The holes are drilled just behind the spar cap but forward of the foam core taper in the wing skin. I then cut an access hole in the LH seat pan so that I can adjust the trim system friction without removing the seat pan.
Access Hole in Seat Pan
Access Hole
Access Hole
Pitch Trim Lever Mounting
