Brief Description: Header Tank Drain Valve Bracket
Drilled and bent up a bracket which will hold a quick drain for the fuselage header tank. The bracket is made from 2034-T3 .063 sheet. Drilled on the mill and bent with the brake at work. The bracket will be mounted in the lower left corner of the firewall and belly intersection.
