Fabricated two L shaped brackets and two rectangular brackets that will be used to connect the control tunnel (just aft of the wing) to the top of the wing. Connecting the two items will stiffen up the bottom of the fuselage. The brackets bolt together using AN-3 hardware. The brackets are made from 2024-T3 0.063 sheet aluminum. Time includes making a dimensioned drawing from a non-dimensioned full size drawing in the manual. I'm not one to trace a photo copy of a photo copy!
