Milled alum angles to shape, Seat Belt Brackets, Rudder spring mounts, Gear Door #1 strut mount,and Gear Door #3 actuating arm stops. Used mill at work. Still need to sand in radii. The blue in the picture is dye-chem. It removes easily with MEK after all the shaping is complete.
