Rough Day! A little shop time helps some times! Could not sleep so I continued with the wing TE trimming. With the LH done I carefully measured the cord length of the upper an lower LH skin at the tip using my tip template. I then transferred the measurements to the RH side. I started with the upper skin and drew a line between the wing tip mark from the template and the point where the LH upper skin intersected the wing centerline. Decided to delay cutting until tomorrow due to bad mood and the need to double check my dimension with a fresh brain
