Brief Description: Leading Edge Laminte - 4th Ply completion
Added the last two pieces of cloth to comlete the forth ply of the leading edge. I also test sanded the edges of the two pieces a laminated a couple of days ago. The technique of extending the laminate past the recess and then fairing back is going to work great! Pictures to follow. I cut these last two strips wider (maybe 2.75 inches) to make it easier t o get the laminate past the upper and lower edges of the recess.
