Brief Description: Leading Edge Laminate - 4th Ply
I sanded the Q-Cell filler that I filled the lower leading edge recess with. It came out so nice I decided to spot fill a couple of areas on the upper leading edge recess. I then layed up two of the four strips of cloth that make up the forth ply. I let this ply extend past the edge of the recess. I will then feather the laminate egde back to the the leading edge recess edge. This should make a nice LE laminate with a bare minimum of filler required to finish. I am not against filler exactly but the leading edge of a wing takes a lot of abuse both from flying and handling.
