Bill's Glasair Odyssey
Date:  3-5-2009
Number of Hours:  3.00
Brief Description:  Control Rod Clearance Check
Finished the controls installation to check pushrod clearance to the wing rib clearance holes. I clamped 1x2s to the wing ribs to limit the control throws per the manual. I actually set it up to throw a little farther just to be safe. I marked minor changes to the openings to provide the required 1/4 inch clearance.
I then removed the controls, adjusted the openings and routed out a small margin of foam to prepare the openings for sealing with Q-cell.
