Bonded on the forward wing CL doubler. This is the same as the main doubler, just shorter and more curved.
Installed the wing condiuts through the new wing tip ribs. I cut a hole through the wing tip rib using a dremel tool. I then put the PVC tube through the wing tip and applied a Q-Cell radius on both sides of the ribs.
