I completed the rear spar face layups that I started yesterday. I knife trimmed yesterday's first ply layup even with the spar foam. I then cut ten additional pieces of cloth to complete the layups with. I ended up using a 80-90 gram batch of resin to put down each full length piece of cloth. I had to take a couple of breaks to let the plys tack up before putting additional plys over the top.
Tomorrow I will knife trim these plys and proceed with laying up the rear spar caps on the upper wing skins.
Knife Trimming Rear Spar Laminates
View Of RH spar layups
Center of Rear Spar Layups. Dark areas are overlap joints
