Been away sick with the flu for one week. Good to be back to the project! I ran out of resin so I had to promote a fresh gallon. I made the first four capstip layups on the RH upper wing skin. There are a total of twelve cap strips per wing half. Each strip was cut to three inches wide. This will give me about 1.25 inches on either side of the rib. I will then trim these back to 1 inch overlap after they are cured. I will make the remaining layups on the RH skin tomorrow night.
