Bill's Glasair Odyssey
Date:  1-6-2009
Number of Hours:  3.00
Brief Description:  Upper Wing Panel Fit, Pitot Static Tubes, Pitot St
My friend Rob tack welded my pitot mount for me. I then cleaned off the mill fiber tacks that I had used to hold the mounting plate in position for tack welding. I sent the ready to finish weld mount home with Rob to finish weld. At the hanger I started looking at the centerline joint on the two upper wing panels. There was a gap of close to a 1/4 inch between the panels. The LH panel end was pretty straight and landed right in the center of the center rib. The RH panel edge was not so straight. I transferred the LH panel edge onto the RH panel using a flexible straight edge. I then measured the minimun distance from the transfered line to the RH panel edge. I used this dimension to draw another line right next to the panel edge. I sanded to this line. This resulted in a straight panel removing the minimum amount of material. The resulting fit of the centerline seam was much better with a gap of about 1/16 of an inch.
I mixed up some cabosil and loaded into a syringe and filled all the holes in the ribs were the pitot static tubes run. This completes the pitot static tubing.
I mixed up some pure resin which I thinned down a little with acetone. I painted this thinned mixture on the landing gear trunion mounts just to seal them after the extensive sanding for landing gear fit. I used a thinned resin so as not to build up any significant thickness which would mess up all my careful sanding and fitting.
RH FWD trunion mount after thin resin coat
Typical cabosil fill on pitot static tube
Cabosil fill on thru holes
